TwinTurbo.NET: Nissan 300ZX forum - Re: No spark cylinder #1
Mglide86
on March 12, 2017 at 9:11 PM
posted by Mglide86
on March 11, 2017 at 10:37 AM
Problem solved fellas. Orange and blue wire were smashed and barely holding on by a copper strand. Thanks for all the help. I really appreciate everyone on this forum. Salute
Mglide86
10:37:31 03/11/17
Check the connectors for corrosion on the coil pack
MixManMash
13:09:28 03/11/17
Re: Check the connectors for corrosion on the coil pack
Mglide86
14:11:34 03/11/17
Check continuity between the signal wire and the PTU
MixManMash
20:11:57 03/11/17
Re: Check continuity between the signal wire and the PTU
Mglide86
09:19:23 03/12/17
Note - the upgraded PTU is installed using an adapter
jzack
10:42:25 03/12/17
Re: Note - the upgraded PTU is installed using an adapter
Mglide86
10:50:33 03/12/17
Here's how it all works. ECU sends a pulse to the PTU for
jzack
16:44:37 03/12/17
Re: Here's how it all works. ECU sends a pulse to the PTU for
Mglide86
21:10:01 03/12/17
Great, glad you found it. Yes, these cars need to be run
jzack
21:33:31 03/12/17
Mglide86
19:07:25 03/12/17
You might have better luck with some small picks/tweezers
MixManMash
21:08:09 03/12/17
Re: No spark cylinder #1 -
Mglide86
21:11:37 03/12/17
